GE condenser fan motor
Old 06-04-17, 07:36 PM
6
My son called me today. He is looking for a replacement fan motor for his condenser.
Model number HE3E195n
230 volt 1100rpm 1/5 hp
Model number does not come up on an internet search.
Anyone know of a universal motor he can install on his unit?
Thanks,
David
Old 06-04-17, 07:42 PM
Received 1,113 Votes on 1,033 Posts
Motor model numbers mean almost nothing. The majors buy skid loads of motors with their private model number on it.
What is the complete model number of the condensor ?
Old 06-04-17, 08:08 PM
6
Thank you for the reply Pete.
I will get that info from him.
Old 06-04-17, 08:17 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
I haven't seen a GE condenser in a long time. Is his condenser from the 70's or the early 80's?
Seems like I remember some of those units having a 2 speed condenser fan motor.
I used to omit the 2 speed control relay on those things and install a single speed motor. You wouldn't want to spend too much money on a 35 year old condenser.
You will probably need to measure the motor diameter or read the Frame size on the motor nomenclature if it is still legible.
I liked the electrical section on the 3 to 5 ton sizes.
Probably time to consider a new system.
Old 06-05-17, 04:52 AM
6
This is what I have.
Any thoughts?
Thanks,
David
Old 06-05-17, 05:51 AM
6
Son's unit...
Rheem
Motor number HE3E195N
230 Volt
1/5 hp
1100 rpm
5 5/8" motor case diameter
Single flat on shaft?
My unit...
Rheem
Motor: AO Smith F48SF6L5
230 volt
1/4 hp
1075 rpm
Double flat on shaft?
Specs on my motor are from the internet.
I only see one flat on his motor shaft.
Can't see the shaft on my motor.
Do you think my motor would work on his unit?
What's this double flat on my shaft?
Thanks
David
p.s. Suggestions on removing fan blade from his motor?
Soaking with Blaster right now.
Old 06-05-17, 10:58 AM
Your motor might have 2 set screws. Its always best to use a exact match on motor. That said I would use that motor. When I have a stubborn fan blades I heat up the set screw area with a torch. Works for me every time.
Google Condenser rescue motor.
Old 06-05-17, 12:10 PM
6
skaggsje thank you for the info.
Son works at Grainger and motor is in stock.
It will be installed this evening.
David
Old 06-05-17, 02:34 PM
Your welcome David, let us know how it turns out.
Old 06-05-17, 05:08 PM
6
As you stated... a little heat and a few blows with the hammer and the fan blade came off without any damage.
Son took it home to install it.
Old 06-06-17, 07:44 AM
6
Motor is installed and all systems are A-OK.
Ready for lift off.
Thanks everyone for the help and advice.
David
Old 06-06-17, 05:07 PM
Thanks for letting us know how you made out.
