Casement Window AC question
Old 06-18-17, 01:45 PM
C
I have a 14 3/4 inch opening in my window. The casement AC i'm looking at says it 14 5/8 inches wide...I'm thinking that it'll fit but I read down farther on the spec sheet and it says it needs a minimum of 15 1/2 width for it.
What is the extra 3/4 inches for? I don't have it. Will the 14 5/8 fit?
thanks joe
Old 06-18-17, 02:09 PM
V
Received 2 Upvotes on 2 Posts
What does the Manufacturer have to say on this matter ?
Old 06-18-17, 02:10 PM
XSleeper's Avatar
Received 1,810 Upvotes on 1,628 Posts
A link to the spec sheet or instructions might be helpful.
Old 06-18-17, 02:19 PM
C
it say that the width of the unit is 14 5/8 inches and then it says minimum opening (width) 15 1/2 inches. I can't figure it out. 14 5/8 will be a tight fit but it'll work and if I do need 15 1/2 inches for some reason, I'm out of luck.
Old 06-18-17, 02:30 PM
czizzi's Avatar
They usually have baffles attached to the side to close off the rest of a traditional window opening width. The unit dimensions are probably for the metal box of the unit itself without the baffles.
Old 06-18-17, 05:58 PM
C
Can those baffles be removed OR can I just insert the unit into the opening as far as those baffles?
Old 06-18-17, 06:30 PM
czizzi's Avatar
My experience is that you add the baffles after the shipment of the product. So technically, if the unit will fit the opening, not adding the baffles will work. You can add thick foam padding to take up the small space where the baffles would have been. It is the balance of the vertical space that you will need to account for on a casement or sliding window. Make sure your casement will open to a full 90 degrees before committing to your unit.
Old 06-19-17, 03:06 AM
C
Thank you. Yes the widow does open up far enough to slide a unit in and I will support it from the outside.
Thank you for your input...very much appreciated
Have a really great day.
joe
Old 06-19-17, 03:34 AM
V
My suggestion was to give them a call to clarify the apparent discrepancy in the measurements in the sales literature before buying the unit.
It's Monday morning; Customer Relations should welcome the opportunity, and may also want to eliminate the confusion that their literature causes for other potential customers as well.
