Frigidaire window A/C: compressor not staying on long enough
Received 0 Votes
We just installed a 6000 BTU unit in a 200 sq. foot bedroom. The air coming out of the unit when the compressor is on is about 40 degrees. I have the thermostat set on 60. The unit only runs at night when the outside temp is in the upper 70's and by a.m. in the lower 70's. I have yet to get the bedroom below 66 degrees. The when the compressor is not running it is blowing about 55 degree air. The back of the unit is free of any obstructions and I have put styrofoam inserts in front of the side "wings" and no air gaps around the unit and window frame. From what I can tell it is just that the compressor does not run enough. I would like to get the room down to 64 with the thermostat set on 64. Any ideas as to what is going on with this unit? The unit has been installed about 4 days now and the house has central AC set on 75.
Thank you in advance for any help and insights on what might be the issue.
According to the chart I just looked at, a 6000 BTU AC is good for 150 - 200 sq ft room. So, your room is at the top of its ability to cool that room. That's if your room has an 8 ft ceiling. If its a higher/taller ceiling than that, its just more space (cubic ft) its got to cool. The air conditioner just may not be big enough to cool that space down to 60 - 65 degrees.
55f suggests the compressor just shut off. That figure will rise to match room temperature.
If you need the compressor to run at a lower room temp.... remove the front face plate. The filter will be IN this plate. See if there are two sensors on the evaporator (cold coil). Let me know.
Received 0 Votes
1. This unit is rated per box to cool 250 sq. ft. I chose that one as I know a larger unit might not run long enough to take the humidity out of the air.
The room is service by central a/c and maintains lower 70's all day long. I only use the window unit at night as I sleep better in a cooler room (65 is perfect) with low humidity.
2. I looked underneath the filter and only see one sensor. Shall i take picture of it? Perhaps I am missing one.
This is the 6000 BTU unit that Lowes sells. When the compressor is on it is blowing 39 degree air per the infra-red thermometer I used.
I did check the air very shortly after I heard the compressor quit and that is when it read 55 degrees, so my bad.
I have central A/C in my home which keeps the house temperature around 72 degrees. However, like you, I like it cool (mid 60's) for sleeping. To further complicate matters, my desktop computer is in that room and if it's on for any length of time, it heats up the room another 2-3 degrees. I have a small 5000 BTU window A/C unit that I turn on a couple of hours before bedtime to cool the room (~170 sq. ft) down. It usually gets the room temperature down to 64-66 degrees, depending upon how long it's been on and what the humidity level is in the house.
If that sensor is directly touching the coil..... try moving it slightly away from the coil. It will read the room air more and not the cold from the evap coil.
Watch for ice build up on face of evap coil.
Received 0 Votes
Thank you Pete,
It was directly attached to the fins so I have gently detached it and pulled it away. I look forward to seeing if I can get the room down to 65 degrees to night!
Let me know how it works out. Sometimes that sensor is used to detect ice buildup.
Some units have two.... one for each purpose.
Received 0 Votes
Well I ended up pulling the sensor from behind the grill and letting it dangle and last night it got the room down to 65 which is all I am asking it to do and the outside temp never got below 77 so all, while not perfect is good. Thank you for all the help and knowledge shared!
