Soleus Air MT1-19-32
Hi there!
Recently purchased Soleus Air MT1-19-32 misting fan. In the beginning worked very well and was perfect for the use I bought it for.
BUT, after only a couple weeks of use the unit is so plugged up with minerals I am unable to get water through anymore.
I called Soleus Air and they tell me the unit is designed not to plug up and they have no procedure to deal with this. When it first plugged I tried putting some vinegar in the unit. It helped for a day or two.
Does anybody know how to deal with it? All help and suggestions will be much appreciated.
Welcome to the forums.
I'm not familiar with that unit so I went directly to the reviews. Several people mentioned that since there are no nozzles there is nothing to clog. The majority of the users had no clogging problems and no complaints.
You either need to use purified or filtered water if your water is that bad.
Your only other choice would be to return it for a different model.
