Rheem Prestige Error 27 no or low voltage to the outside unit
Old 08-13-17, 11:36 AM
Hi Guys,
I checked the breaker and it looked nice and snug. I still took it out and pushed it back in all the way making sure it was fit. We did have a storm last night that knocked the lights out for a second, which is when I suspect the outside unit stopped running. The inside unit comes on as normal but nothing at all on the outside unit. No noise, no humming, nothing. It is completely dead. I opened it up and the display is flashing 27 with the red LED a solid lit. I dont know what else to test for the voltage as I couldnt find any videos on youtube that seemed similar. Any help would be greatly appreciated.Name:  prestige_ac_ALL1.jpg
Size:  44.3 KBName:  prestige_ac_CircuitBRDall.jpg
Size:  46.4 KBName:  carrier_ac_compressor1.jpg
Old 08-13-17, 11:58 AM
Bob14525's Avatar
Received 12 Votes on 9 Posts
Did you check the outside electrical disconnect? It should be located near the outside unit and is there to provide an easy way to turn off the power to the outside unit. Some of the disconnects have fuses inside. If your disconnect has fuses, it's possible that one is blown.
Do you have a multimeter? They are very handy for troubleshooting these kinds of things. If you don't have one, you can pick one up at Harbor Freight for <$10.
Old 08-13-17, 12:11 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
I would turn off power to the indoor and outdoor units for 90 seconds to try to reset the error code.
Old 08-13-17, 02:30 PM
I did check the disconnect on the wall next to it and made sure it fit. There is no fuse in that box.
Old 08-13-17, 02:50 PM
Like BOB said your next step is a voltmeter.
Old 08-13-17, 02:57 PM
What's the best way to turn it off to reset?
Old 08-13-17, 03:41 PM
At the breaker box in the house. There should be one for the furnace and one for the outside unit.
Old 08-13-17, 04:19 PM
Thanks guys, turning it off and on fixed it. Who knew HVACs were just like windows
