Mini split AC
Mini split AC
I have some problem
my 24000 BTU GREE inverter AC have some error cord LC
in indoor unit dishply
Compressor is not run some times outdoor fan work
That is a startup failure. See below.
Gree Air Conditioners Error Codes
Is this a new unit or just a new problem on an existing unit?
The fault code is telling you the compressor is not starting. Now you need to go outside, open the unit and check the compressor. It could be a contactor or an inverter problem. May not be an easy diagnosis.
Is this something you're trying to repair yourself ?
You'll need a meter and know how to use it.
Probably going to need the service manual too.
A model number would be helpful.
