24VAC Line for Trane AH for Honeywell Lyric T5
Old 03-18-18, 03:59 PM
I
Hello,
I'm trying to connect a my new thermostat (Honeywell Lyric T5). I have a Trane TWE049E13FB2. I do not have a C wire.
My current thermostat is a Trane. It is wired like this
Y2 = Blue
R and RC = Red
O = White
Y = Yellow
G= Green
My air handler looks like this.
G - Green
W1 = White
R = Red
X = Orange
YLO = Yellow
These are the connection to the condenser
The orangish wire goes to the condenser and the dark brown goes to my tstat.
The Orange wire that hooks to X on the board is wired to the Blue (Y2 on tstat)
My new tstat has this
I thought I could connect the Green G wire to C then on the AH connect the G to the B wire and jump the YLO to the G wire is this correct?
Old 03-18-18, 07:32 PM
Received 3,892 Upvotes on 3,489 Posts
Welcome to the forums.
I'm looking over your stuff. I see two stage cooling.
Is this is a standard split A/C system with electric heat or a heat pump ?
I don't see any electric heat checked on the air handler decal.
Old 03-19-18, 03:09 AM
I
Yes it's a standard split system. I have electric heat.
Old 03-24-18, 12:28 PM
I
Do you think I have the right idea?
Old 03-24-18, 01:04 PM
I
My Air Conditioner is a Trane XL19i.
Old 03-25-18, 01:11 PM
Sorry for the delay. I was trying to find more info on the air handler. Normally all the power for the stat and the condensor come from there but there is no visible connection from the AH to the condensor for common. It appears the air handler runs at different speeds depending on the input so I'm not sure at this point if you can jumper the G to the Y wire.
We know at the stat.....
R/Rc ------> red
W1 --------> white
G ----------> green
Y ----------> yellow
Y2 --------> blue
We know at the AH....
G - Green (G)
W1 = White (W1)
R = Red (R/Rc)
X = Orange (Y2)
YLO = Yellow (Y)
Out to the condensor I see....
W1 ---- > white
R -------> red
Y ------> yellow
Y2 -----> blue
I don't see a C (B) connection to the condensor.
