Mini-split install gree 4 zones
Hey I just purchased a gree 4 way mini split system. I was hoping for some advice.
My goal is to have the units in the bedrooms run up to the attic then down to the garage via a closet in the house. With just the drainage pipe through one inch hole on the wall angle down to the outside house behind each unit.
For the living room space(kitchen, dining room, living room) open space I wanted to put an unit above the kitchen cabinet. It’s high ceiling so plenty of space there. The idea would directly above the fridge and cabinets. But the oven would be below and to the right of the unit.
The idea is that I don’t put pvc outside the house. But it all runs through the closet and through the garage. Then just one hole in the garage to the unit outside.
Welcome to the forums.
Pretty ambitious job. A little heavy for DIY.
What advice are you looking for ?
We cannot discuss or help you with the refrigerant (charging) part of the system.
