One condensate pump, 2 AC units
Old 04-30-18, 03:22 PM
K
I have a single condensate pump and 2 AC units in my basements. The condensate pump's overflow switch is only wired to one of the two units. (I actually have a dehumidifier that's also draining to the same pump.) Everything has been working well, but I feel that this is a (flood) disaster waiting to happen.
What is the right way to wire a single pump with multiple sources?
Old 04-30-18, 03:28 PM
Received 3,748 Upvotes on 3,361 Posts
You would need to add a DPST (double pole single throw) relay into the mix.
The float switch would control the existing unit directly and the relay would need to connect into the 2nd A/C and the humidifier.
