Condensor Fan Needs A Push
Old 05-03-18, 04:53 PM
A
Question Condensor Fan Needs A Push
Hi. I have a Rheem RAMA 060JAZ 208-230 volt central air system. Lately, I have to occasionally give the fan on the outdoor unit a push with a stick to get it going. It then runs and cools the house well.
I would like to try to fix this myself. Where do I begin in figuring out what needs to be replaced?
Thanks in advance.
Old 05-03-18, 05:19 PM
Received 128 Upvotes on 113 Posts
99.9% of the time it's the capacitor that's bad.
Old 05-03-18, 05:26 PM
R
Received 199 Upvotes on 181 Posts
Test the capacitor vs it’s original rating
Old 05-04-18, 04:12 AM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
Another thing you can do is check the motor bearings.
Turn off the circuit beaker to the unit and remove the fan shield.
Carefully grasp the fan blade and gently rock it back and forth to see if you can detect ANY side to side movement of the motor shaft.
This is more easily done with the fan blade removed but can be done while still installed.
Old 05-05-18, 02:22 PM
A
Thank you Joe, roughneck77, and GregH.
Old 05-05-18, 03:35 PM
Received 3,982 Upvotes on 3,574 Posts
If it turns out to be the capacitor.... it should be a dual run 80+5mfd @370vac round capacitor.
Rheem OEM # 43-23204-29
(always check visually with current part)
Rheem parts list/Rheem/92-42800-RAMA.pdf
Old 05-17-18, 04:30 PM
A
Hi. It was the start capacitor. I replaced it, but it continued to trip occasionally, albeit much more sporadically (like every other day instead of twice daily). I took your advice and ordered the unit you suggested. It's a dual capacitor. My unit had separate start and run capacitors. I'm a little confused now about which wire goes where. The new 43-23204-29 unit has three ports--Herm, Fan, and C. The old start capacitors ports were unmarked. I'm also unsure of where to reroute the start capacitor's wires to. Which wires go where from the old start capacitor and from the current run capacitor? Thanks!
