A/C not cooling.
Old 05-04-18, 06:51 AM
A/C not cooling.
Turned on my central air unit but not cooling the house. The fan outside is running and the filter inside is clean just replaced. I did notice that air coming from the unit outside is not hot so o don't think it's sucking out the heat from inside . any advice will be great .
Old 05-04-18, 07:07 AM
Is the compressor running?
Old 05-04-18, 07:27 AM
R
Received 199 Upvotes on 181 Posts
The fan running outside would indicate it’s getting a call to run. Make sure the compressor is actually running.
Old 05-04-18, 08:32 AM
How do I check that ? Thank you for the help
Old 05-04-18, 08:47 AM
R
See if the contactor is pulled in, and the compressor is pulling amps.
You should be able to hear the compressor running as well
Old 05-04-18, 09:05 AM
Sorry to be a pain but how do I check the contractor? I have limited knowledge on AC units .
Old 05-04-18, 09:12 AM
R
First off, feel the suction and liquid lines. Is the suction line cold? Is the liquid line warm?
The contactor will be in the electrical cabinet in the condenser. There will be live exposed high voltage in that panel.
Old 05-04-18, 09:17 AM
And if any of those items are not functioning correctly is this something a lamen like me can fix ?
Old 05-04-18, 09:24 AM
R
You should have a meter and be ok around high voltage. May be a capacitor.
Old 05-05-18, 12:19 AM
C
Received 7 Upvotes on 7 Posts
It is not easy to fix a 'not cool' problem. It can be caused by many different issues. so you may have to call an AC tech to help you.
