Carrier A/C: drain pan clogged
Old 05-06-18, 07:51 PM
Hello I have a Carrier AC FA4BNC048 Looks like my water drainage got clogged and PAN is filled up with water.
Need instructions to remove water from drain.
any manuals out there for me to check them out please
Old 05-06-18, 09:00 PM
XSleeper's Avatar
Received 1,922 Upvotes on 1,726 Posts
You likely either need to clean the drainage hole in the pan or the drainage hose out with compressed air.
Old 05-07-18, 06:58 AM
Thanks XSleeper for quick response how do I open or get to drainage pan, any instructions are helpful
Old 05-07-18, 10:35 AM
R
Received 199 Upvotes on 181 Posts
The pan is under the evaporator coil.
You can try suction on the drain line with a shop vac.
Old 05-07-18, 10:40 AM
Received 3,983 Upvotes on 3,575 Posts
Pictures of what you have are helpful too.... How-to-insert-pictures
Old 05-07-18, 04:18 PM
Attached are some pics.
Thanks roughneck77 I used the vacuum a while back for about 30 minutes or so to drain all water out and poured with Clog remover liquid and also vinegar.
Is there a Fan Filter for this AC Unit?
Old 05-07-18, 04:38 PM
R
Yes, there is a filter. Should be changed every 3 months. I hope you’ve changed it before
Old 05-07-18, 06:30 PM
Is that the only drain line connected ?
It doesn't look like it connects to anything.
It looks like the return may come up from below. The filter should be in the return line.
Old 05-07-18, 09:07 PM
not sure how its connected but that's the drain line seems be the white pipe which is at bottom.
Old 05-08-18, 04:08 PM
I only see a 6" piece of PVC. Where's the rest of it ?
Where is the water draining too ?
Is there another line elsewhere that we can't see in the pictures ?
That may be a dead end fitting for a float switch.
Old 05-08-18, 06:58 PM
Attached a better picture for clarity and more angles of all pipes I have connected to UNIT.
yes you are correct 6" piece of PVC is the float switch will it help if I pour clog clear liquid inside it?
Old 05-08-18, 07:36 PM
NO.... use no drain cleaners.
Ok..... much better. I didn't see the primary drain line as it's in that black foam.
That line is what is clogged. The 6" 'PVC fitting is the overflow or secondary drain line.
You need to find out where that lines goes in the wall. That is the line that is clogged.
It's PVC.... it may have to be cut open in order to clean it.
Old 05-08-18, 08:36 PM
Thanks Pete I used a water vacuum for drain line outside my house and for now luckily so far I don't see any water is being stagnant or leaking.
now I am wondering if I have to do some maintenance like cleaning "Fan Coil Filter" is that some where to be found or cleaning the coils by opening the UNIT...what your expert advise
Old 05-08-18, 08:37 PM
R
So you’ve never changed a filter ever in this unit?
How long have you lived here?
Old 05-08-18, 08:53 PM
regular filter I have changed it...may be I should say furnace filters if I have any for my UNIT
Old 05-09-18, 07:26 PM
There should only be one filter. It will be in the return line. It may be behind a large return grill in a wall. It should look like a typical furnace filter. It won't be inside the air handler. It will be external.
You can "clean" the drain pan by removing that float switch, pouring in one cup of bleach and then flushing it with at least a gallon of water. The bleach will flush the algae and muck out of that area of the pan. Best to do it when the A/C won't be used for a day or two to allow the bleach to drain out.
Old 05-15-18, 07:21 PM
Got it thanks Pete
