Fan isn't spinning
Old 05-20-18, 11:40 AM
A
Fan isn't spinning
A/c in 99 mobile home, had it hooked up last July, heat and a/c has been working fine. Yesterday the fan quit spinning. Figured it was frozen somewhere, shut it down, ran fan on. Still isnt spinning almost 24 hours later. When I attempt to run it, when I stand outside I can hear a series of clicks and relays, but no fan movement. We're in the process of debating using this as rental unit next year after we build/but a home, or outright selling it to add to down payment on home. Inside A unit is 3 years old, pretty sure outside unit is original. Any ideas? Model # BRCQ0421BD, if that helps
Old 05-20-18, 12:51 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
Are we speaking of the indoor fan motor (blower) or the outdoor fan motor (condenser fan)
The culprit is usually a run capacitor.
Does the fan spin freely with power removed?
Old 05-20-18, 01:02 PM
A
The outdoor condenser. I don't know if the fan spins freely with it off. I'm a bit hesitant to start pulling things apart without guidance.
Old 05-20-18, 01:15 PM
Houston204's Avatar
If you turn off the thermostat and get a small stick, can you spin the fan?
https://www.hamiltonhomeproducts.com...BRCQ-Parts.pdf
Old 05-20-18, 02:57 PM
A
The fan spins freely in both directions
Old 05-20-18, 03:15 PM
Houston204's Avatar
I would turn off the breaker to the outdoor unit and remove the service panel to see if the capacitor is swollen. (It will be)
Take a picture or 2 of the capacitor and post them here.
It is labeled 9 in the manual that I posted.
Old 05-20-18, 03:25 PM
Received 3,424 Upvotes on 3,070 Posts
A little info on picture posting.... How-to-insert-pictures
Old 05-23-18, 08:43 AM
A
Included a pic of the capacitor, fan motor, compressor and whatever that blue thing is out in the corner. My daughter just told me she'd heard what sounded like leaking when the air would cut off last week, coming from under the house, so now I'm wondering if it's a compression issue and if the compressor needs to be replaced and recharged.
Old 05-23-18, 04:02 PM
Houston204's Avatar
That dual capacitor requires replacement. It should not be swollen on the terminal side but it is...
Z97F9848 - 35 + 5 uf MFD 440 Volt VAC - GE Round Dual Run Capacitor Upgrade https://www.amazon.com/dp/B00EZPO11K..._HmFbBbHQW8TA5
Old 05-23-18, 06:30 PM
The insides of that unit could use a little cleaning.
That filter (blue thing) in the last picture is rusting out laying in the mud.
Be sure you pull power to that unit before doing anything inside it.
Old 05-23-18, 08:22 PM
A
Its actually sitting on some sort of psuedo slab made of plastic. I wasn't here when it was hooked up after the house was placed. It was originally supposed to be by the back door, on an elevated spot, it all got moved right by the front door, where water collects when it rains. The filter, aka, blue thing, is that a standard filter I can pick up at a supply store, or a special order?
Old 05-24-18, 09:46 AM
Houston204's Avatar
The filter/drier is part of the refrigerant circuit. Just clean that area,clean off the filter drier and spray some Rust-Oleum on it.
