Removed A/C Blower to Clean Now No A/C
Old 05-20-18, 04:18 PM
I cleaned my coil today and noticed a lot of mold in my blower. I took the blower out and cleaned it as well. I put ever thing back and now the AC doesn't turn on. Nothing happens when I turn on the thermostat.... inside or outside. Any suggestions? Is there any way to send power to the blower fan to make sure the motor works fine?
Old 05-20-18, 04:23 PM
Houston204's Avatar
Received 10 Votes on 8 Posts
There are a few things to check...
Did you wet the motor? This might trip a breaker
Is the door switch depressed? I sometimes need to bend the door switch closer to the door
Did you turn off a square D breaker type service disconnect? Those things are prone to failure.
Old 05-21-18, 05:44 AM
Will Compressor run if Fan Faulty?
If tge inside fan blowwer motor is broken, will the outside unit also not turn on?
Old 05-21-18, 05:57 AM
Received 1 Vote on 1 Post
I think it will short cycle, because it will have no "load".
Sid
Old 05-21-18, 06:09 AM
I cleaned my blower and coil and now nothing happens when i turn the unit on. I have power inside on the main yellow
Old 05-21-18, 07:39 PM
Received 340 Votes on 318 Posts
Threads combined. We keep all like posts on one topic contained in one thread.
There is a safety switch on the blower door. If it's not pushed in tightly by the door.... nothing will work.
Not sure what the yellow line is. Pictures are very helpful. How-to-insert-pictures
Is this a furnace or just an air handler ?
A model number of it is also helpful.
As mentioned.... it doesn't matter if the inside blower is working.... the outside condenser will run for a short while until it overheats or freezes up and then it needs to cool before restarting.
