Blower not running in A/C mode - Yunggbuggs
Old 05-28-18, 04:18 PM
Y
I am having this exact same problem minus the disconnected wire .. there's also water pooling a little bit underneath my coils should I clean I out before turning the breaker back on and trying to restart it which I also can't get it to do .I
Separated from: blower-not-running-in-a/c-mode
Old 05-28-18, 05:42 PM
Received 3,420 Upvotes on 3,066 Posts
Welcome to the forums.
These problems are specific to the make of the equipment. Unless you have the same exact problem with the same exact equipment..... your problem is not the same.
Start from the beginning. A make and model of the air handler/furnace.
Split A/C with gas furnace ?
Heatpump ?
