New Install AC Only
Old 06-12-18, 01:13 PM
B
New Install AC Only
Experts chime in. Looking at adding a SpacePak to my raised ranch with an English Basement but only to the 1st floor. Built in the 60's with radiant heat copper tubing in concrete basement floor and plaster ceilings on 1st floor. Attic is high enough to stand in center. Walabot used to locate copper lines in ceiling which is also why I prefer not to use conventional duct registers (too large and might hit copper line). Will keep Spacepak lines/registers close to walls and away from copper lines. I have located area in center hallway for the return duct. I have sized the Handler (# of lines) and don't feel need for basement cooling since I have an open staircase and will let physics take over to move the warm air up and the fact the basement is usually cool enough just a little humid. Looking to hear from the SME's.
Old 06-12-18, 06:01 PM
Received 3,420 Upvotes on 3,066 Posts
Welcome to the forums.
What is your question ?
What would you like to hear ?
