Help! Problem with my AC setup
Old 07-01-18, 08:16 PM
I moved 5 days ago to an old building and Iím having water leakage problems. I donít know much about ACís but I really want to fix it. Thereís a pvc pipe leaving the furnace and there is a Tee at the start of the setup. The Tee is heading up and itís not covered. As soon as I turn on the AC it gets flooded and starts dropping water. Should I cover that Tee to see if that would solve the problem? Thank you for your help
Old 07-01-18, 08:22 PM
Hereís a picture of my pvc pipes setup so you can have an idea of what I am talking about[img]https://*******/m7csuy[/img]
Old 07-01-18, 08:25 PM
][img][/img][/url]
Old 07-01-18, 08:29 PM
Old 07-01-18, 09:32 PM
Houston204's Avatar
Received 10 Votes on 8 Posts
I recommend that you Hit it with a shop vac.
Old 07-02-18, 08:54 AM
jjrbus's Avatar
Received 1 Vote on 1 Post
Here in the third world country of Florida we have to attach a shop vac to the drain line outside every couple months or they plug up with mold. Change filter, vacuum drain line is the normal maintenance.
Some people seem to not have an issue with it, mine will plug within a year if not done.
