AC Blower not working
Old 07-03-18, 06:30 PM
Having trouble with my AC. The unit was working fine last couple days during heat wave. Today, when thermostat clicks on, the outdoor portion operates but the indoor fan / blower does not (There is no air flow throughout house). The fan DOES work and operate when I turn off AC and set fan to On on thermostat. But then if I switch it to cool, when AC clicks on the fan stops.
Iíve got a Rheem Criterion II furnace, fwiw. I checked / cleared the condensate line but still no fix. Any insights?
Old 07-04-18, 12:19 PM
Bob14525's Avatar
What happens if you turn fan to ON (fan starts up), then turn A/C on. Does the fan continue to run, or does it turn off when A/C comes on?
Old 07-05-18, 09:23 AM
Fan turns off immediately
Old 07-05-18, 10:59 AM
Bob14525's Avatar
If you have a multimeter, check the voltage between the R & G and R & Y terminals on the thermostat. Ideally, you should measure 0VAC between the the terminals. If you don't have a multimeter, try connecting the R, G, and Y terminals together and see if the A/C and blower come on. R is the 24VAC (power) connection to the thermostat. Y controls the outside unit, while G controls the blower. When the thermostat calls for cooling, relays inside the thermostat connect the R to Y and R to G terminals. If the R to G relay isn't working properly, the blower won't come on when the A/C turns on.
