A/C fan stoping and starting
Old 07-05-18, 03:39 AM
R
When my AC turns on sometimes the fan will stop and start a few times before settling in to run. Had a local company come and look at it they replaced the capacitor which helped a little bit but less than 2 weeks and its still doing it. Could this be caused by either the thermostat or possible be the switch for the blower ? any and all help would be welcomed,
Old 07-05-18, 05:22 AM
R
Received 185 Upvotes on 169 Posts
Which fan, the condenser or the indoor blower?
Old 07-12-18, 05:05 PM
R
the outside unit runs but the inside will cycle a few times before it will stay running.
Old 07-13-18, 03:52 AM
Bob14525's Avatar
Received 59 Upvotes on 50 Posts
If you change the Fan switch on your thermostat from Auto to ON, does the blower still cycle on/off?
Old 07-17-18, 04:04 PM
R
It still cycles on and off I checked the fan motor and its not warm to the touch
Old 07-21-18, 12:46 PM
R
Any ideas or suggestions would help
Old 07-21-18, 12:49 PM
R
Check the call for the blower from the thermostat with your meter. To see if it’s controls or line voltage related.
