A/C leaking water
Old 07-22-18, 09:09 AM
L
A/C leaking water
Lou, sorry to bother you but there is a problem with the AC. I noticed this morning it got really hot , so went to check it, thermostat set on 72 but was reading 80 In the house. I shut off the unit and then a few minutes later heard dripping. The AC unit is leaking water from the bottom. I put pans under to catch the water but not sure what else to do. The drip is slowing but it’s still going. Please advise.
any suggestions?
Old 07-22-18, 09:17 AM
Received 1,316 Votes on 1,216 Posts
Sounds like a clogged/plugged drain line.
Is this a central air system or a window A/C ?
Bob14525's Avatar
Received 27 Votes on 22 Posts
It sounds like your condensate drain line is plugged up. You apparently have a float in your condensate tray that turns off the A/C if the water level gets too high, that's likely why your house is hot. You should see a small diameter (typically 3/4") white PVC pipe that comes out of the air handler. This is your condensate drain. You could try using a wet/dry vacuum cleaner to suck out whatever is clogging the line. Do a Google search on cleaning A/C condensate line for other ideas on clearing the clog.
Old 07-22-18, 09:28 AM
L
PJ, yes it’s a central AC unit
Old 07-22-18, 09:53 AM
Then your 3/4" PVC drain line is plugged. For specific help we'd need to see pictures of the install.
How-to-insert-pictures
