AC clicks and off with 1/2 a second happens every 5-10 minutes
Old 07-27-18, 11:59 AM
L
I have already had 4 HVAC companies try to figure this out. No luck. Every 5-10 minutes the circuit board inside will click. The board has 2 green lights and 5 red. Every 5 to 10 minutes
  • the #1 green will click off while #2 and #3 Red simultaneously will click on...
  • 1/2 second later it will happen again and then not for 5-10 minutes
  • Meanwhile outside...when the board does the above the compressor clicks on and off within 1/2 second.
We have already moved and replaced thermostats. We replaced the circuit board a few years ago. This is a Lennox unit.The ac cools nicely but only stays on 5-10 minutes at a time. see video by copy/paste at https://photos.app.goo.ql/gDTeVhQ8YVfv1xwA8
Old 07-27-18, 12:06 PM
P
Received 240 Upvotes on 204 Posts
Could be the control board is bad. I've had to replace mine two times within 6 years. I was lucky that the warranty covered them. Is this a Heat Pump or just A/C?
Old 07-28-18, 10:22 AM
Received 3,415 Upvotes on 3,063 Posts
Welcome to the forums.
One topic is contained within one thread. This is your only thread on your A/C problem.
Your video link is not working.
What is the model number on that Lennox condenser ?
Old 07-30-18, 07:58 AM
L
Just the AC. I was afraid it might be the control board again. Thanks for your reply.
Old 07-30-18, 08:01 AM
L
I will check that and get back to you.
Old 08-02-18, 09:33 AM
L
Lennox compressor : M/N 13ACX-048-230-12
Old 08-08-18, 07:34 PM
L
I am told my unit is a heat pump
