A/C compressor wire melted off
Old 08-07-18, 10:10 PM
Hi need some help here. My A/C compressor red wire keeps burning off . Not sure what is it maybe high amp draw? Anyone know what it might be? Thanks for any help!
Old 08-07-18, 10:17 PM
Received 3,420 Upvotes on 3,066 Posts
Yes.... it is a high current connection and if not solid and tight will continue to burn up.
Depending on the type of compressor they offer terminal repair kits.
Old 08-08-18, 12:18 PM
I got a terminal repair kits and just installed it...hope that will fix the issue. Thanks i will keep you updated if its still burning the wire.
Old 08-08-18, 04:23 PM
Good job. Once the fittings are tight..... your problems should be solved.
Old 08-22-18, 12:25 PM
compressor wire melted off gain...what should i been looking for? Is it the capacitor bad or wrong size?
Old 08-22-18, 03:47 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
Did you clean the terminals with a wire brush before installing the terminal repair kit?
What kit did you try?
Old 08-22-18, 04:55 PM
sorry, I opened the cap and it seem the wires are fine. nothing was burn. I thought it burned off again but this time it wasn't the case. Everything is working 100% now thanks!
Old 08-30-18, 05:02 PM
me again...so today the yellow one burnt off. Also I noticed it tripped off the circuit breaker this time. Please view pictures and let me know if you see anything wrong or not right?
Old 08-30-18, 05:13 PM
Those terminals are clean and tight ??
They don't look like it in the pictures.
Old 08-30-18, 05:21 PM
when the red one burnt off ... I just replaced and clean the red wire. I didn't clean the other ones.
Old 08-30-18, 05:35 PM
They all need to be clean and solid. There should be shiny metal connections.
Any corrosion at all will cause the terminal to run hot and melt.
Old 08-30-18, 06:27 PM
okay I will clean all 3 with light sand paper and wire them up again with the terminal repair kit. Thanks for the help!
Old 08-30-18, 07:45 PM
would a bad or wrong size capacitor cause the issue?
