AC compressor fan
Old 08-17-18, 12:36 PM
K
AC compressor fan
I recently purchased a compatible ac compressor fan motor for my Lenox model HS25-651-1P and the fan turns much slower. It has been cooling fine but seem to take a little longer to reach the temperatures which is no big problem but it tripped the breaker after running pretty good for a couple of days. I'm wondering if I connected it properly? Is there a way that I could turn the speed up to get more rpm's? It is a 825 rpm and is turning much slower than the original 825 motor
Old 08-17-18, 01:25 PM
R
Received 183 Upvotes on 169 Posts
Are you certain it’s wired properly, and did you also replace the capacitor with one of the correct rating for the new motor?
