Need help with Wiring Ecobee4 (2stageheat/1stage cool/Humid)
Looking for help with new ecobee4 setup. Here is the equipment:
Rheem Two-stage Heat/one-stage Cool Gas Furnace
AprilAire 560 Evap. Humid
Questions: How do (or can) I connect the Ecobee4 to control everything and eliminate the Humidistat…in essence I have 7 available wires…and I am wondering if I NOW can get a Common wire back in the mix to avoid the extra Power Kit setup…
It seems that there were 5 wires going to HVAC Thermostat and 2 wires to the Humidistat control (next to each other on wall). The C (common) terminal on the Thermostat was not used (batteries in Thermostat)
Connections before beginning:
Thermostat to Furnace
C -->
G --> G
R --> R
Y --> Y/Y2
Y2
W --> W
W2 --> W2
Furnace to Outside AC
C --> [outside unit]
Y/Y2 --> [outside unit]
Humidistat to Humidifer
Wire 1 --> Transformer ŕ Solenoid
Wire 2 -->ŕ Solenoid (bypassing transformer)
Any suggestion would be great…I’ll post a couple of pic if they help.
Thanks
C -->
G --> G
R --> R
Y --> Y/Y2
Y2
W --> W
W2 --> W2
Thanks
Last edited by PJmax; 09-21-18 at 10:35 PM. Reason: cropped/enlarged/reoriented pics
Welcome to the forums.
A few little glitches here........
1) What model thermostat is that old one ?
2) The wire colors on the stat do not all match the furnace colors. That suggests splices.
...... Will need a picture of the splices.
The Ecobee can replace the old stat and run the humidifier.
You will need 7 wires from the furnace to the stat.
Yes...there are splices...I tried to describe the connections in the post:
The five wires that you see on the thermostat (White-Rogers 1F81-51) go (via splice) to the Furnace board as follow: (these are marked not by color, but from the terminal to terminal designation)
G --> G
R --> R
Y --> Y/Y2
W --> W
W2 --> W2
the two wires from the humidistat go directly to the Humidifier with one of them split to attach to a dedicated transformer (there are no other connections on that transformer.
I see NO other transformer in the system...
All splices done just outside the furnace...and I'll try to attach a pic...but it's a mess...
G --> G
R --> R
Y --> Y/Y2
W --> W
W2 --> W2
Ok..... then since you know the splices.....
G --> G ---> G
R --> R ---> Rc
Y --> Y/Y2 ----> Y1
W --> W ----> W1
W2 --> W2 ----> W2
Convert one of the humidifier wires from the furnace to the h'stat for C use.
The other wire will connect to ACC+ at the stat and go directly to the humidifier.
The second humidifier wires goes to the C terminal at the furnace. That second transformer will no longer be used for the humidifier. The humidistat will no longer be needed either.
G --> G ---> G
R --> R ---> Rc
Y --> Y/Y2 ----> Y1
W --> W ----> W1
W2 --> W2 ----> W2
That too was my initial thought...that a one wire setup would work, leaving me the second wire to then be used for Common...
Out of curiosity, with the previous setup (with no wires going from humidifier/humidistat to furnace, does that mean the humidifier was always on when the humidistat was set to on?
Thanks for the advice!
