Help with bad compressor in Payne packaged unit
Ok thanks I will post some pictures tomorrow.I have another question if you can help me on this.
I have a mobile home with a 5 ton package unit that the compressor quick and don't work anymore.Right now I can afford to buy a new one and I will like to try to fix if you think that is worth to change the compressor. I know that a compressor can run for about $1000 and up.the unit is a Payne 5 ton the compressor is a Copeland Scroll 2 stage or 2 speed scroll 220 volts R-22 refrigerant .I have seen some compressor new from $ 300.00 to $500.00.My question is do I have to get the exact model or I can get away with a 5 ton Copeland Scroll 2 stage or 2 speed 220 volts R-22 refrigerant the specs are almost the same but the model number is different.
My unit is a Payne Model # PH3ZNA060000AA. The compressor is a Copeland Scroll Model # ZRS52K4-PFV -130.
Can you please let me know if it is wroth it fixing the unit.Thank you
the compressor makes clicking noise but won't start.I did check all the legs with the meter and every test like that is fine.but that is all it does.The compressor in my unit is a 2 stage compressor.thank you
Bad Compressor
Need some help with choosing the right compressor.I have a Payne 5 Ton package unit that the compressor is bad,My question is do I need to find the exact model of compressor or can I get away with a compressor with the same quality .
My compressor model : Copeland scroll Payne 5 ton ZRS52K4-PFV -130
The one that I found is Copeland scroll model
Payne 5 Ton ZR57K3-PFV-23
Can this one replace the bad compressor?
Threads split/combined. Two threads running on the same topic is extremely confusing.
Keep the Payne stuff in here and the Goodman in the other thread.
Help choosing the right compressor
Hello guys I really do need help with this Payne 5 ton package unit.Does anybody knows a little about replacing bad compressor ?
My question is do I need to get exact compressor model or I can get away with finding a compressor pretty closed to the one I have.for example mine is a Copeland Scroll 5 ton (52000 BTU) 2 stage single phase 220 volt R-22 refrigerant. Model ZRS52K4-PFV -130 .They don't make or have this model anymore.I found one Copeland Scroll 5 ton ( 57 000 BTU) 2 stage single phase 220 volts R-22 refrigerant Model ZR57K3-PFV-23.The only thing I need to know if I can replace this one for my bad compressor. Please I need help.Thank you
