Line to PTAC Unit
Old 11-09-18, 07:48 AM
Line to PTAC Unit
Good Morning,
Retired Building Contractor with minimal electrical knowledge with a question!
I'm installing a 9000 btu Amana Air/Heat Pump (through-wall) unit and need some confirmation or advice on the Breaker, Wire, and Receptacle.
The PTAC unit is rated for 230/208 volts, volt range 197 to 253, Max Overcurrent Device is rated at 15 amps. It has a permanent cord rated at 15amps 240Vac.
What I have already installed: 15amp breaker in the panel box, 10/2 wire running to the unit, and purchased a Hubbell single receptacle rated at 20amps 250v w/ horizontal blades and ground.
What I need to know is, do I use the white wire also as a hot, since the receptacle has two brass screws? If so, in the panel box can I attach the white wire to the other side of the screw opposite the black wire on the 15amp breaker, or should I replace it with a 2 pole 15amp breaker?
Or, does anyone suggest another option?
Old 11-09-18, 08:45 AM
airman.1994's Avatar
stop stop stop! Please use a double pole breaker!!!!
Old 11-09-18, 10:18 AM
Okay, no problem I can do that. Do you see any other problems with my questions, or do you have any other suggestions? In other words am I good to go after switching out the single pole breaker for a double pole breaker?
Old 11-09-18, 10:20 AM
I’m not quite sure what your attempting but your getting ready to cause an electrical fire.
You have a 208-230V unit. You need a double pole breaker.
Old 11-09-18, 12:48 PM
Okay, so I switch out the single pole 15 amp breaker to a double pole 15 amp breaker, and everything else I described is good to go?
Old 11-09-18, 01:39 PM
Same two wires going to the breaker must go to each hot side of the receptacle
Old 11-09-18, 02:26 PM
Okay Great, that helps thanks!
