Air conditioner issues
Old 11-11-18, 07:35 PM
U
Our aircon is having issues that nobody can seem to fix. Some days it works perfectly fine and others it just spits out warm air and this seems to happen on the hottest days!
Alot of the times, no matter what temp we put it on, it will only do freezing cold air and even then, after a few hours, it goes back to spitting out the warm air again.
We have 2 units in the house. Upstairs and downstairs. They used to both be able to work at the same times but now when we turn both on, only one will work.
Any advice would be so much appreciated. We've had repairmen come over the years and the problem has never been solved. The last time someone came to look at it, he replaced some of it and we hoped that would fix it. Another person said it was gekos, but once he had cleaned out the gekos, the problem was still there.
Old 11-11-18, 07:40 PM
Received 3,415 Upvotes on 3,063 Posts
Welcome to the forums from down under.
One thread per topic - Post moved to the A/C forum.
We're going to need a lot more than that to help you.
If you have repairmen on site that can't fix it how are we going to help ?
It sounds like you need the outside units cleaned and serviced.
