Need Ideas Why Water Dripping from Ceiling Vent in Winter
Old 12-10-18, 01:58 PM
T
Received 2 Upvotes on 2 Posts
I have a square ceiling vent in a bedroom that drips water maybe once per 5 minutes and:
1.) It's the middle of winter and the high is 35 degrees F.
2.) It's an A/C only system, not a heat pump;
3.) It hasn't rained for over 10 days;
4.) The attic just above has blown-in insulation and the flex duct is insulated;
5.) There are no water pipes in the attic;
6.) There is no condensation sheen on the ceiling vent, just one spot that drips;
Does anyone have any ideas on something I can do? ...like tape some plastic over the vent to see if it's condensation vs. dripping through. I'll be looking at it tomorrow in the attic a second time; the 1st time, I could find no stains and no water under the attic insulation.
Thanks!
-TonyT
Old 12-10-18, 02:10 PM
XSleeper's Avatar
Received 1,920 Upvotes on 1,724 Posts
Take the grille off and reach your hand in there. It's probably condensation from warm air in the house coming into contact with cold air in the attic. I bet you have a puddle that has collected inside the ductwork and what's dripping is because the puddle is running over.
Old 12-11-18, 01:11 PM
T
Xsleeper, thanks for your reply; I did look at it today and went into the attic.
When I removed the grille, there was indeed moisture inside the insulated flex duct where it turned from vertical to horizontal; you were right.
So, what is the fix? Put some bat insulation over the flex duct in the attic? Or put a cover over the vent? The dripping occurs even when the vent is fully closed.
FYI: I found a ton of moisture in the attic but how would it ever make its way into a closed system of insulated flex duct --> Air Handler --> Central Return? Unless it's just a coincidence. I'll be venting the shower and dryer vents to the outside this week.
Thank you.
Old 12-11-18, 04:40 PM
XSleeper's Avatar
I assume it's condensation... humid air from inside the house condensing on the inside of a cold duct. The solution in in my opinion is that all ductwork needs to be positioned as low as possible.... then covered with a ton of blow in insulation. R-49.
If fresh air from outside is somehow washing down this ductwork, that would be bad. So all the seams in the ducts need to be taped and air sealed.
Old 12-12-18, 12:43 PM
T
I have wrapped the offending flex duct (only one vent is dripping) with R19 batts for about 6 feet today. I'll wait and see if it stopped. It's not dripped for the past 10 years, so I'm thinking crazy perfect conditions may have pushed the condensation point just barely over the edge and that the insulation MAY protect against those rare conditions.
If it continues to drip, I will try a cover for the 12"x12" vent, stopping room air from migrating into the cold attic flex duct. I found a product called AC Draftshield which is made for this exact thing.
If it STILL drips, then I'll have to install a thermostat that turns the circulation fan on randomly during each day. I don't know much about them, so I'd have to look more into that.
Old 01-10-20, 10:16 AM
where you able to figure out a way to stop the dripping of your ac vents? I also am fighting the same issues. I have tried everything and I can’t seem to fix the issue. I’m going to drill air vents under my over hang of my house I think this weekend to bring in more air flow
Old 01-10-20, 10:41 AM
T
Atticus: I don't know if I found the problem, because a few drips still do occur.
This place is occupied by tenants and they both take a shower every day. My best theory is there's SO much humidity in the air from the 2 daily sowers, that it's just floating up into the large central return which is on the ceiling in the hallway RIGHT at the bathroom door!
So I asked them to keep the bathroom door closed during showers and keep the bathroom exhaust fan on for an extra hour after finished with their showers (I installed a timer for that).
Since that change in behavior, the dripping has almost stopped, but like I said, we still get a few drips here and there. I DID purchase and install the product called AC Draftshield that catches the drips, but it's not a lot an they evaporate nicely while laying in the plastic tray/cover.
Old 01-10-20, 03:35 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi, why are you finding so much moisture in the attic, are the exhausts vented outside, do you have a ridge vent, is the insulation pulled back a bit from the soffit vents ?
Geo
Old 01-10-20, 04:47 PM
T
Geo, who are you asking ...me or Atticus?
Old 01-11-20, 04:08 AM
Geochurchi's Avatar
Hi Tony, you are the one that said “ A ton of moisture “ ,the venting would apply to all attics.
Geo
Old 01-11-20, 05:45 AM
A
Received 279 Upvotes on 255 Posts
Is the entire attic damp or just the inside of the air conditioning duct?
Simply taping plastic sheeting over the vent will keep humid interior air from going up the duct and condensing water vapor inside the duct. (Remove the covering come summer.)
Cold outside air entering a bath fan vent duct perhaps aided by the wind will not condense moisture inside the duct.
Old 01-11-20, 09:43 PM
T
Thanks for your posts! ...but I had both bath vents vented to the attic, but that's been long corrected and there's no moisture in the attic. You may be referring to posts I made last year which have been resolved. A NEW post just came up by Atticus who was asking what my fix was. I don't have any problems anymore ...you may need to read through all of the above posts.
