Evaporator coil in bad shape
Old 12-31-18, 01:21 PM
Z
So, I just moved into an apartment, and I noticed that the fins on my evaporator coil are in bad shape. Maintenance has cleaned them 2 times now. They look mostly clean, but some are cracked, deteriorating and bent badly. Please see the photos attached. This is a 'heat pump' system. Please answer my questions below.
- Does this evaporator coil need to be replaced?
If so, why?
- Can this make my utility electric bill more expensive, or will it definitely?
- Is this a health or safety concern?
Overall, the maintenance crew is saying, there is no need to replace it and it is as clean as it can get. Also, they are saying, they don't need to replace it, because the temperature in the apartment is fine, as well as the temperature coming out of the vents. They are correct on that, it does heat fine for it being Winter.
- Will this be a bigger issue in the hotter months? I am in Atlanta, GA.
Old 12-31-18, 05:27 PM
Received 3,880 Upvotes on 3,477 Posts
Welcome to the forums.
Thread moved to the A/C forum.
I don't see any attached pictures....... How-to-insert-pictures
Missing fins are for the most part not a major concern. There are no health risks.
It can detract from the overall system efficiency.
Old 01-01-19, 11:26 AM
Z
Photos
I don't have a paperclip or advanced button to upload photos.
Old 01-01-19, 11:55 AM
I'm guessing you're using a phone. Check your PM's.
Old 01-01-19, 12:29 PM
Z
Photos
Your correct. What are my PM's?
Old 01-01-19, 02:16 PM
PM = private message. Go the top right corner of the page. Do you see a bell there with a 1 on it.
Click on it.
Otherwise go to the top of the page where the hyperliks are and click on private messages.
Old 01-01-19, 06:14 PM
Z
Photos
See attachment, for the way my evaporator coil looks currently.
Last edited by PJmax; 01-02-19 at 07:00 PM. Reason: resized main pic and add closeup pic
Old 01-02-19, 07:54 AM
Z
What are your thoughts on if this coil and padding shown in the photo should be replaced or not?
Old 01-02-19, 07:02 PM
From where I'm sitting that coil looks pretty plugged. Is there a lot of the insulation caught in it ?
Insulation that is decomposing and shredding should be replaced.
Old 01-07-19, 05:47 AM
Z
Insulation
I am not sure about the insulation, since this is an apartment. They are scheduled to come out this week to try and straighten out the fins with the correct size fin comb and clean the fan inside. The fins are actually pretty clean, they just look dirty, because some dummy bent them up using the wrong size fin comb cleaning them. Zoom in, you may be able to see what I mean.
Old 01-10-19, 04:23 AM
Received 14 Upvotes on 11 Posts
From the pictures, it looks like the coil is just dirty. The build-up could be insulation but I would bet it is just a very dirty coil . The prior tenant could have not replaced the air filter when necessary or never installed one. Either way a dirty evap. coil is had to clean due to it's location.
