Caulk for storm collar on furnace and water heater exhaust on roof?
Old 01-18-19, 11:41 AM
H
Hello,
Not sure if this question belongs in HVAC or Plumbing or Roofing.
Please move it if needed.
What caulk do you use on the storm collar of a furnace or water heater pipe to make it water tight? It will be exposed to UV and elements and high heat (not sure how high of temp though).
I would prefer non-silicone caulk in gray or clear.
I called Loctite and they say that their Roof and Flashing caulk could be used. This is black but it can be painted if needed.
I called 3M and they gave me a few suggestions and the common one is 3M FB3000 WT. This is gray but it is silicone based.
One roofing supplier suggested caulk from Chemlink, possibly a silicone based.
What is a good caulk to use, whether it is one of the above or others?
Thank you.
Old 01-18-19, 12:13 PM
XSleeper's Avatar
Received 1,940 Upvotes on 1,742 Posts
Solar Seal #900 or Geocel 2300... both available in clear. Either would be a good choice.
Old 01-20-19, 09:32 AM
H
@XSleeper
Thank you, I will look into these.
