Identifying cond. fan wires
Old 04-24-19, 09:31 AM
Is it possible to ohm out fan wires to identify for proper connections to compactor ? This 3 wire motor has 1 black and 2 red. Thanks in advance.
Old 04-24-19, 06:45 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
Is this motor designed for the unit you're installing it in ?
Remember there are 120v and 240v motors.
I black and 2 red wires is an odd color combination.
With three wire motors..... there is a run, a common and a start connection. You'll need an ohmmeter to check for the winding resistances.
Start to Common = middle ohms reading..... so for example 10 ohms
Start to Run = highest ohms reading.......... 15 ohms
Common to Run = lowest ohms reading...... 5 ohms
Once you have the three wires labeled they can be landed. Don't forget a capacitor is needed.
Old 04-24-19, 09:52 PM
I think this motor may have been rewired at some time. Thanks for the info, just what I needed.
