Which DIY mini splits have precharged lines and don"t require vacuuming?
Old 06-11-19, 06:50 PM
F
So far only Mr. Cool units seem not to require vacuuming. Could someone please list the brands that are truly diy without special equipment e.g. vacuum pump? In many cases it is suggrsted that vacuum pump is not required, but fine print says it is. The Mr. Cool I am considering is the 12000 btu 115 volt model that is Alexa compatible. But it is $1100+ and I wonder if there are cheaper ones that don"t require vacuuming. Your help is very much appreciated. Thank you. Frank
