Fan not running
Old 06-12-19, 10:46 AM
Fan not running
Good morning,
I have an older Lennox unit, HS29-030-2P. On Sunday, the a/c was working fine and then it started to feel a little warm in the house. I look outside and the fan on the top of the unit is not working but the unit still seemed to be trying to run without it. I did some research that said that it could be the capacitor. I ordered a new one and installed it and the fan still isn't working. I have a new fan motor arriving today. Is there anything else that could be wrong with it in case the new motor doesn't work? I just want to get a few other ideas in case I need to figure something else out. Thanks!
Old 06-12-19, 10:51 AM
Received 1,034 Votes on 958 Posts
Welcome to the forums.
That looks like a standard 2-1/12 ton split A/C. (If it was a heat pump there would be a fan relay.)
You replaced the cap..... not much else could be bad.
Make sure the cap value matches the replacement motor.
Old 06-12-19, 11:04 AM
G
Received 2 Votes on 2 Posts
Also a lot of the older Lennox units had pressure switches.The high might have to be reset if so.
Old 06-12-19, 11:07 AM
It appears that the compressor is running so it sounds like the pressure switches are ok.
Old 06-12-19, 11:36 AM
How do I check if the capacitor and motor match? I got a PowerWell 35 + 5 MFD uf PW-35/5/R 370 or 440-volt Dual Round Capacitor and the motor I got is a Lennox Central Air Conditioner Condenser Fan Motor. Horsepower: 1/6, Voltage 208-230, Full-Load Amperage 0.86, Hertz 60, RPM 1075, Speed 1, Rotation CCW, Frame 48, Enclosure Closed and Shaft length 2.5". Will it work with the two voltages being different? Thanks again for the help!
Old 06-12-19, 11:40 AM
The voltage is fine. The required cap size is printed on the motor.
Old 06-12-19, 11:50 AM
Ok awesome. I will double check the cap size is on the motor before I install the motor to make sure it will work. Thank you!
Old 06-13-19, 06:07 AM
It was the motor! Thank you both for your help! I really appreciate it
Old 06-13-19, 09:12 PM
Good job. Thanks for letting us know how you made out.
