AC still whining after fan motor/capacitor replacement
I have a Goodman GPC1330H41CA that started emitting a low screeching/whining sound last week. I've lived at my home for a little over a year now, the AC was installed 5 years ago by the previous owner. The sound started last week out of nowhere so I researched possible causes and assumed it was the fan motor based on what I had read.
Ordered a new motor and capacitor, swapped them out this morning. The noise is still there, it sounds like it is possibly coming from the compressor underneath the fan motor but I can't find anything loose or any visible leaks anywhere. However at this point the problem appears to be above my pay grade so I'm sure I will need to call someone. The unit itself seems to be running perfectly fine otherwise.
Just wondering if anyone had any similar problems or knows a possible solution that I haven't tried yet. The noise has not gotten worse, can't be sure if its metal grinding or not. Sounds kind of like air being pinched out of a balloon so that's why I thought possible leak if the valves/pipes/whatever are corroded.
Thanks for any input, have a happy 4th
That appears to be a packaged unit, That means it will have two fans in it. One fan is for the A/C condenser and the other is the main blower for the house air flow.
