One dual run capacitor vs two single capacitors
Can I replace 2 capacitors (80 and 5 uF) with a dual run (80 + 5 uF)? And vice versa?
Thank you.
A related question. Existing condenser fan motor is 1/6 hp 825 rpm. Can I replace it with 1075 rpm same hp?
Thank you.
Changing from two caps to a dual run cap involves a bit of rewiring.
In my opinion..... two caps is superior to a dual cap system.
Is that an ultra high efficiency unit ?
Upsizing the speed like that will increase the motor size to approx 1/2hp.
Fan blades are rated for the motor they come with. You'd need to make sure that the blades could even take an increase in speed. Overall.... not a good idea.
