Evacuating refrigerant lines
Old 07-21-19, 07:49 AM
D
So, I have installed a mini split system and everting is a go until I reached the step of evacuating the refrigerant lines. The hose from the manifold to the service inlet does not connect. I watched a couple of youtube videos and it looks like they uses a small coupling of some type. I have no idea where to find one or what size it would be.
Popular Reply
07-21-19, 11:09 AM
roughneck77
roughneck77 is offline
Received 101 Votes on 95 Posts
It’s 5/16” X 1/4”.
Make certain you do a proper nitrogen pressure test, and use a micron gauge while evacuating.
Old 07-21-19, 08:38 AM
5
Received 11 Votes on 10 Posts
You need an adapter. Most local supply houses in your area should have them.
https://www.supplyhouse.com/Yellow-J...1-4-Male-flare
Donnygreen1 voted this post useful.
Old 07-21-19, 08:45 AM
D
That looks like the one! I'll update my post if that works.
Old 07-21-19, 11:09 AM
R
It’s 5/16” X 1/4”.
Donnygreen1, Rugerhound voted this post useful.
Old 07-21-19, 09:42 PM
Received 1,018 Votes on 945 Posts
Welcome to the forums.
Just keep in mind that the information already offered is about all that we can give you as
charging a home A/C system requires an EPA issued refrigerant handling license and based on
that...... discussions are not allowed in the open forums.
doityourself.com/forum/air-conditioning-cooling-systems/charging-your-A/C
Old 08-06-19, 08:12 PM
D
As advised by 57TinkerMan and Roughneck77, it was exactly that. There is a 5/16 x 1/4 fitting required to connect the hoses properly in order to pull a vacuum in the refrigerant lines. The only thing being evacuated is air. The refrigerant is never physically handled as it is self contained within the unit in a sealed system.
Thanks to both for your help!
