Thermostat wont shut off when it reaches set temperature.
Old 07-22-19, 10:19 AM
T
Received 2 Votes on 2 Posts
The control module is a White-Rodgers 1F86-244.
If I set the temp to 74, sometimes the thermostat will not shut off, and will keep cooling until I turn it off... it will go down into the 60's if I dont notice it.
I've tried resetting the module (hold up/down, and move selector to heat)... sometimes this fixes it, but after a few days it will start acting up again.
I imagine I need to replace the control module, but before I did, I wanted to run it past you guys to see if there is anything else that might be causing it.
The control module is probably 10-15 years old, and hasn't had problems until a few weeks ago.
Popular Reply
07-22-19, 07:12 PM
Houston204's Avatar
Houston204
Houston204 is offline
Received 17 Votes on 14 Posts
If you can turn off the thermostat and the indoor fan as well as the outdoor unit turn off it would point to a thermostat problem.
It sounds like it is time for a new thermostat.
Old 07-22-19, 07:12 PM
Houston204's Avatar
PJmax, tiresharkdbb voted this post useful.
Old 07-22-19, 10:12 PM
Received 1,043 Votes on 967 Posts
I agree. The problem you are describing is a sticking relay inside the thermostat.
