Rheem Startup Capacitor Info Needed
Old 07-22-19, 10:58 AM
I have a bad AC startup capacitor in my Rheem AC system. The Rheem is a Corsaire series, Model Number 13AJA48A01, Serial Number 7281N120604924, built in 2006. The system had the original capacitor replaced a few years back with an Aerovox SH1238. The replacement capacitor has no voltage Specs on it, but does have the designations of "TT 10000 AFC Protected". I would be very appreciative if somebody could provide either the original Rheem part number, or at least the voltage specs I need. Thanks in advance.
Old 07-22-19, 07:02 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
https://www.rheemparts.com/parts/Mod...eatherKing.htm
I suspect that you may be talking about a run capacitor instead of a start capacitor.
According to this manual the part number for the dual (Run) capacitor is 43-26271-39. It won't let me "select" to bring up the values without an account number.
The voltage is going to be 370 or 440.
The 440 is better but it may not fit in the hole that Rheem often uses for mounting.
Do you know the microfarad value listed on your dual capacitor
Old 07-25-19, 09:25 AM
Thanks for the response Houston204. No I do not have any of the info related to the microfarad. Also, thanks for the link to the parts list!
