Portable Unit cutting out
Picked this unit up however do not know the history of it. It's a Honeywell brand portable air con unit
Model: AMH-1200E
It cools but only for 5 minutes then stops working. about an hour later it will cool again for a bit then stop.
Cant see any water anywhere however i notice there isnt any hot air (or any air) coming out of the vent which the ducting takes outside.
Attached is a picture of what looks like a waterwheel, i assume its simply a fan and is for pushing air into the ducting. This doesn't spin at all.
Any ideas?
thanks
Model: AMH-1200E
Any ideas?
thanks
Yes, it sounds like the unit is broken. You said you "Picked this unit up...". Where did you pick it up?
At my workplace, long before me. We've had fixed units for 5 odd years now. It's not been run in over 8 years atleast other than the fan function.
Trying to clean up and wondering if it's an easy fix or worth recycling and getting out of the way
Recycle it. Even when new they have a short life and I've not seen one last past 8 years. Most seem to die because of a freon leak. The fans run and you can hear the compressor run but it doesn't make cold air. And of course they don't have ports for adding refrigerant.
