Leak in Condensate Line
Ok forum, I am attempting this step by step. I know it may seem like an easy fix. But I will be attempting to clear the Condensate Line for possible build up. Of course all the pics and videos I see are different from my AC unit. If my picture came out, the leak is from the hose at lower right. Just need to be sure the top portion that needs to be removed.
The two flexible, gray "pipes" going to the steel electrical box are electrical conduits with wiring inside. Water shouldn't but it can get inside them. To the left is the condensate drain made of rigid PVC pipe and fittings.
