Contactor Wires?
Old 08-06-19, 09:28 AM
Contactor Wires?
Trane TTB036C100A1 I want to change my contactor. The original contactor only has 1 Red Power feed wire. The replacement CTR02574 has 2 (bottom) terminals. Will this work?
( I understand I need to connect the 2 24 volt wires and the other 2 red top wires)
Old 08-06-19, 11:15 AM
Received 1,046 Votes on 970 Posts
Welcome to the forums.
Although only one set of switching contacts is needed..... I can't remember ever seeing a single pole contactor in a unit. We can see the red wires are being switched. What was done with the black wires ?
The replacement contactor you're going to use is the correct one. The two power wires coming in go on L1 and L2. Keep the red wires on the L1 - T1 side. The T side of the contactor is the wiring going to the compressor and fan. The blue and white 24vAC wires stay on the side of the contactor.
Old 08-06-19, 11:33 AM
Pete,
Thanks for the response. I am not sure where/what the Black wire is connected to. I can look further tonight when I get home but I would rather not rewire/change it, as it has been like this since new in 1999.
Can I ignore L2 & T2 and connect all others wires as you describe above?
Unit is currently working fine, I just changed the bulging capacitor and thought it would be a good idea to change contactor as well.
Jeff
Jeff
Old 08-06-19, 12:12 PM
Yes... you can just use the L1-T1 switched contact.
