Blower Running Constant
Old 08-20-19, 08:12 AM
We had a recent lightning storm pass and nearby ground strikes damaged several electronics in my home. Here are some details I'm hoping to resolve:
  • Problem: blower runs constant, regardless of settings at the thermostat
  • Lennox residential system - approx. 16 months old
  • Single unit, zoned in a 2-story home (upstairs + downstairs)
  • Replaced the zone board (HZ311)
  • Should I:
    • Replace the capacitor on the ECM motor (attached: 100600-02)
    • Replace the transformer (attached: 42J3201)
  • Do you suggest I troubleshoot anything else? (ie: control board in the air handler)
Thank you, in advance, for any assistance/recommendations!
Shawn.
Old 08-20-19, 07:26 PM
Tolyn Ironhand's Avatar
Received 862 Upvotes on 725 Posts
No.
Only if it is not putting out 24 volts (aprox)
If you disconnect the thermostat red wires at the furnace does it stop?
Old 08-20-19, 07:40 PM
R
Received 199 Upvotes on 181 Posts
Test for a call for the blower with your meter.
It’s likely either the thermostat or control board. A quick test with a meter will show what’s going on.
The parts you pictured have no effect on your problem.
