Window A/C compressor won't turn off
I have an LW1217ERSM window unit. The compressor will not turn off even if I press off
Welcome to the forums.
That is becoming more of a problem with electronically controlled units. The relay contacts on the control board have become welded together. If you are handy or know someone technical..... that relay can be replaced on the board. Otherwise the control board will need to be replaced.
I was looking further. It appears the board is EBR83604002.
In the picture below I've indicated the relay that is defective.
EBR83604002 Board
EBR83604002 Board
