HVAC handler X13 motor blower
Have MARS 10861 azure motor blower in my AC handler. When I connect the harness to 24 volts so the the motor could learn the needed torque, the motor runs for about 1 minute then turns off. I then discount the harness assuming it already learned, however it never work again.
The setup is x-13.
what should I do?
what should I do?
Welcome to the forums.
It sounds like you may not have followed the directions completely.
In the link is a pretty good video where the tech walks thru a complete X-13 setup.
Mars 10861 set up video
