Electric heat: Trane 4tec3f36b1000aa air handler blowing cold air
Old 12-03-19, 03:47 PM
Electric heat trane model number 4tec3f36b1000aa hvac air handl blowing cold air
Old 12-03-19, 10:26 PM
Received 477 Votes on 447 Posts
Welcome to the forums.
That model is an air handler for A/C or heat pump and has provisions for electric heat.
Do you have a heat pump or just a split A/C with electric heat ?
Have you checked the thermostat ? Does it use batteries ? Are they ok ?
If there is an internal problem.....
You're going to need a meter to troubleshoot this unit.
You will probably have to post pictures of the inside wiring area so we can direct you.
