Help with Split inverter AC issue
Hello everyone i have an LG split air conditionner M126EH. I m having an issue with the outdoor unit. When powering up the AC the outdoor fan spins and the rotary compressor tries to start 3 times. I head it starting to rotate but then spinning down. After the third attempt the whole outdoor unit shuts down and remains like that for 3 to 5 mins and the cycle repeats again. I do not get any error code inside. Could anyone please help thanks.
You’d have to check the outdoor unit for any visible errors. It could be a refrigerant or compressor related problem, which would require a tech to diagnose.
That number you gave looks to be for the indoor unit.
Welcome to the forums from Mauritius in East Africa.
It would be helpful if you put non-US in your user bio.
I don't see a service manual available for that unit in the US.
You may need to consult with a local service company for help.
