Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Air Conditioning and Cooling Systems
Reload this Page >
Fixed poor vent airflow by blocking pipe at bottom of my AC unit, is this bad?
Old 05-15-20, 09:35 PM
H
Question Fixed poor vent airflow by blocking pipe at bottom of my AC unit, is this bad?
I'll preface this by saying I am not at all experienced with maintaining any kind of HVAC hardware outside of replacing filters.
Earlier tonight the pressure coming out of my room vents was non existent. I checked the filter, gave it a quick clean, and there was still no airflow. I found a small pipe coming out of the bottom of the unit, it looked like it had been taped over before, and had busted. All the airflow was coming out of there, and the refrigerant pipe was one big icicle.
I went ahead and covered that pipe back up and airflow is back throughout my home. However, I am curious if this is a safe way to fix whatever is happening with the seemingly random duct at the bottom of this unit. The only branding I found on that part of the unit is All-Style. If it's important at all, the furnace is a Dependable Ninety-Two.
Old 05-15-20, 10:51 PM
Received 3,328 Upvotes on 2,987 Posts
Welcome to the forums.
There shouldn't be anything open to let air out.
Can you post a picture of what you have there....... How-to-insert-pictures.
Old 05-16-20, 05:48 AM
P
Received 1,707 Upvotes on 1,525 Posts
Did you tape over the condensate drain? That's the only pipe I can think of the comes out of an air handler.
Old 05-16-20, 06:19 AM
R
Received 178 Upvotes on 164 Posts
You say the refrigerant pipe was iced up. That’s your problem and why your low on airflow. Your evaporator is frozen. Did you thaw it?
Old 05-16-20, 05:31 PM
Received 11 Upvotes on 11 Posts
"Your evaporator is frozen."
^^^^^ Turn the system off and let the evaporator thaw out. Sounds like you have a refrigerant leak - not something you can fix yourself.
Old 05-17-20, 06:00 AM
Geochurchi's Avatar
Received 157 Upvotes on 143 Posts
Hi, if it is the condensate drain pipe you taped, remove the tape before you turn the unit off to defrost, if that’s what’s required.
Geo
