Goodman fan blower will not stop running after changing relay
After changing the fan relay the fan will not shut off i have installed a new thermastat as well
Welcome to the forums.
Double trouble.
Did you try the system without the thermostat connected ?
There are several different fan boards so you need to post the part number for the one you changed.
Typically the blower is controlled by the G wire coming from the thermostat or the purple wire from the heat strips if you a heat pump system or electric heat.
Double trouble.
Very unlikely the new relay's contacts have failed in the closed condition causing the fan to run when relay is de-energized. Your problem is in something else you changed.
Posting a picture of the new relay (as wired) may be of assistance.
It might be as easy as moving a wire.
Goodman ARUF A/C Heater will not run
