Drain line?
Drain line?
On each mini split wall unit, is there a drain line that needs to go to a bathroom or waste drainage or does it go back to the main unit outside via the copper lines?
Is it just a small pipe or needs to be 1"+?
But each outlet/head has condensate or is it only the main unit/pump?
Are you allowed to run small condensate drain tubing in walls, say 15ft to under a sink cabinet?
are there any access blockage issues to consider?
Most condensate drains just follow the copper lines outside and drain to the ground outside.
In cold areas, the hose from the head unit drains into a 3/4" or 1" pvc pipe with an air-gap at top. This allows the pipe to drain out so it doesn't freeze over the winter.
