ice on my AC evaporator coil
Received 0 Votes
Hi,
Just wondering, what could be the problem for my home HVAC system. When I turn on the air conditioning system, the cool air doesn't seem to be strong enough to cool the house. Inside, I find found ice forming on the bottom of the A/C evaporator coils and pipe leading to the unit. I went outside and noticed ice forming on the pipe to the outside condensing unit. Though fan in the outside condensing unit seems to be running properly and I just cleaned the evaporator coils.
Here's a picture of the ice in the a/c evaporator coils. Any idea what the problem could be? Thanks
Ice on the evaporator coil is normally the result of either of two things: insufficient airflow over the coil, or low refrigerant charge. Since you say that the filter is clean and the blower seems okay, it points to a low refrigerant charge. To check the blower, turn the A/C off for 24 hours or so to let the ice on the evaporator melt. Once the ice is all melted, turn on the A/C and see if you feel normal airflow. If you do, the blower is working okay. As the ice starts to form on the evaporator coil, that will block the airflow and reduce the amount of air flow from the registers.
